TV started to to talk about my action
Something happened recently and the TV started to talk, narrating my action.
“select channel” “loading video…” “live TV 4-1 NBC”
like that. How do you turn this off?
Are you using a Roku? I had this happen to me recently, You can turn it off two ways.
  1. Go to Settings → Accessibility → Screen Reader and set it to OFF.
  2. Click on the Options button (*) 4 times in a row to toggle. That is likely how it was accidently set.
There is another setting in Accessibility to turn off that toggle ability.
Yea!! Love you, snowcat!
Your second solution worked. It was so annoying, thank you!
I don’t see Accessibility under Setting though. Yes, It’s Roku.
But it’s all right. Thanks again!
