Tut is a tool to mess with your Tablo(s).
It can be used to manage/Delete recordings on your Tablo’s - easily view/search and display various stats (everything, incomplete shows and more!).
It also allows you to export/copy recordings off your Tablo. It does not (yet) support the plethora of options that, say SurLaTablo, does when pulling and processing recordings (downgrading quality, commercial skip, etc).
You can find the code here:
https://github.com/jessedp/tut#tut
