I just moved my antenna to the outside and rescanned I got the channels I didn’t have before. But at the same time my free trial ended. When I go to the live TV guide and click on the channel (can be any channel) it comes up with a menu to set a recording. I just want to watch the channel I’m clicking on.
Not sure what’s going on.
Clicking on the channel number should start Live TV.
If you click in the grid, Tablo thinks you’re trying to start a recording, but there is a “play” button there too (unless you’re seeing something different because your free trial ended).
Thank you, that is the solution. I am so happy with the amount of free tv I now receive. Moving my antenna outside and 5 feet higher made all the difference. Thanks again for your reply
Best Regards, Alex
