When I was watching live TV on Roku last night, tuner was stuck. Roku
kept playing the same clip over and over again. I couldn’t fast forward to
skip it. It lasted about 15 minutes until I rebooted Tablo. TV signal
was fine. I could watch live TV after rebooting. Has anyone else seen
this?
Are you expereincing this issue?
It sounds quite similar, but I am not sure if it is the same issue. I was only watching live TV
and wasn’t recording it. I don’t know if recording would be OK or not. Since I do have a one-hour
recording which stopped at 27 minutes, I would assume recording would have been cut short
if I had recorded it.
@TabloUser2015 We’re investigating the issue linked above by @roraniel - please let me know if this crops up again. We’re gathering data on this behaviour.
@TabloUser2015 - I have seen this happen several times and have only found a reboot to fix it. It appears to be caused on a weak signal that drops out for a bit, then the tuner just gets “stuck”.
