I have 2 Tablos. Why does one connect OK, but another gets :
There was a problem establishing an authenticated session with your Tablo. This could be due to either authentication or internet connectivity issues.
Also two tablos. Still on firmware 2.2.2. WEB app works fine with one tablo but no connect to the other. Clear Browser cache no help, delete and re-add tablo no help. Original roku app works like a champ on both tablos. tablopreview app works on one tablo but not the other…
But reset the one tablo cleared the problem.
Both dead this morning. Rebooted both - no help. Rebooted the Router, and all is good. Before the Router reboot, my laptop communicated fine with the internet. Router is TP-LINK TL-WDR3600. Laptop is connected to 5.0GHz / both Tablos connected to 2.4GHz.
Have you configured DHCP reservation for the Tablos on your router? If not, give it a try.
What OS and browser are you guys using?
I do have the Reservation in place.
I am using Arch Linux KDE on a Dell E4300 with Chromium.
The original problem occurred while in the midst of downloading with “tablo2go-2.0.55.py”.
When that stalled, I ctrl-C’ed out of that and rebooted the laptop, but only got to the command prompt ( didn’t startx to KDE ). I could “ping -c 3 google.com” fine and dandy, but “ping -c 3 192.168.0.101” didn’t respond. “ping -c 3 192.168.0.102” worked OK.
Then I went to my M6300 running Linux Mint KDE with Chromium and tried to access “my.tablotv.com”. That is where I encountered the error message that is the topic of this whole thing. Then I went to bed…
I also have this problem of not being able to access Tablo on PC with error message:
“There was a problem establishing an authenticated session with your Tablo. This could be due to either authentication or internet connectivity issues.”
On TV, Tablo shows up but since I can’t access it on PC, I can’t record anything. I have Windows 10 Pro and afaik latest Tablo firmware (I can’t check now). My Tablo is less than 6 months old.
Hey mate, hit the red X to delete the Tablo from your PC and then reconnect. That’s what I do when I get this problem and it works a charm.
You rock John Luther! Worked like a charm!
Thank you! I’ve had this problem on my phone forever now, and “deleting” the tablo from the app then reconnecting magically fixed it.
