I’m attempting to record the same show that is on every day at the same time but the system records the show that is on the same channel but one hour earlier.
I use the channel guide and find the show I would like to record. I set up record all. The TABLO records a completely different show that airs an hour earlier on that same channel.
I don’t believe it’s an overall time issue because other shows record correctly.
I’m in Phoenix and it happens on two different channels.
MeTV is the first network and the show is Becker. It’s a 30 minute show that runs two episodes in a row. I have asked the system to record ALL SHOWS but it records the two episodes of WIINGS which airs immediately after Becker.
The second is on the Game Show Network and the show is Baggage. All the details are basically the same. Accept, when I try to record the show it records the two shows of The Newly Wed Game that run prior.
Both of these shows broadcast a total of 4 shows a day, each is two shows running consecutively, in one hour blocks. So, if working properly, this would be a total of 8 hours of recording each day.
I have other shows that were setup the same way by picking from the Channel Lineup and setting to AUTO-RECORD and those work correctly.
I have updated the firmware, channel guide and lineup. I access the TABLO thru my Roku, and that firmware is also up to date.
Similar issue to Lee2. My scheduled recording of ABC World news randomly records another channel some nights. No visible pattern, but when it happens (usually 1-2 nights/week) the recording is of some low definition channel with motocross. I’m in Pittsburgh, PA.
