A few months ago this category showed actual NEW shows, maybe a dozen at any given moment. Now it just shows a bazillion shows that are not new, many multiple years old. It’s not longer useful as you have to wade through pages of old shows to try and figure out what is actually new. Anybody know why this changed? It’s the same on both the legacy and new app.
I reported this problem to @TabloSupport and they had me try multiple things, but nothing worked. Their final solution was for me to replace my harddrives. Since both of my legacy Tablos were recording and playing back recordings without error, I knew that the harddrives were not the cause of the Premiering category not working correctly. It was at this point that I gave up on @TabloSupport and just accepted that it would not work any longer. It started for me shortly after upgrading to firmware 2.2.60. It’s apparently just another one of the features they have broken and don’t have a clue how to fix or possibly don’t want to fix.
Are you using the 4th gen app or the legacy app?
It doesn’t matter whether it’s a legacy app or a gen 4 app connected to a legacy device. The results set is different. But they are both wrong.
This started with 2.2.58 and the switchover to the tablo guide from the gracenote guide. When I use the legacy app on roku and go to the TV Shows Premiering it is displaying what appears to be 175 TV Show icons. Premiering should be the first playing of episode 1 of a TV Show’s new season or the first playing of a one off TV Show special. For the gen 4 app the Premiering ribbon on the Home page is just gibberish. I don’t think I would consider Family Feud season 25 Episode 114 as Premiering.
Out of curiosity, what channel was this showing as Premiering on?
The Legacy app seems to list any shows that have an upcoming airing of S01E01 (the pilot) or any show that lists “Other seasons”. It looks like this may be the same rule the Gen 4 app uses.
I get the same or similar results (I didn’t count the tiles on each) on several different devices and both the legacy and new app, even the legacy PC app, doesn’t matter. It seems to me it is a guide issue with how it is determined whether a show is new or not. The legacy app shows the “First air date” of any show which I think should be the qualifier. Maybe not perfect, as news broadcasts are always new, but would still be a vast improvement over what I see now.
My home page premiering has the CW local broadcast of family feud. Of course I went to check one of my other units to see if it was consistent and it immediately enter offline mode. But the legacy app works fine - Nice.
Not seeing that at all on mine.
That’s nice. I assume you are using the gen 4 roku app against a legacy device. Tablo supports solution to everything legacy is to use the gen 4 app.
How about christmas at graceland (NBC November 30th 10PM) that first aired in 2023. I also have lucky dog that first aired october 3rd. Titaltv doesn’t think any of these are new.
Nope, I’m using the Android TV/Google TV 4th gen app, I didn’t see any mention of what device the OP was using.
The Christmas at Graceland example I DO see, and I would agree it seems to be displaying incorrectly in Upcoming network premieres. Looking at the guide for my area on the TitanTV website indicates the 2023 date as you mentioned:
Makes you wonder if Tablo guide source data incorrectly has it flagged as new?
It’s the guide. Same crap results on many different pieces of hardware and both legacy and new app. That was in the original post. It seems like they are intent on slowly killing their product off until it becomes just another streaming box. And not even a good one.
