I hope that not everyone has had this type of experience, but Tablo is leaving a sour taste in my mouth. For reference I have a DUAL LITE.
To start, the wireless setup just doesn’t work. I am using my.tablotv.com as well as an installed Android app. Get to the page where it says “Connect to your tablo’s wifi network” and when I do, absolutely nothing happens. The console just throws GET http://wifiap.nuvyyo.com/stream/wifi_ping 0 () errors for days.
“Fine,” I say. “I will just set up with Ethernet.” Nope. I connect to my Tablo and the setup doesn’t want you to put in your wireless settings first or give you an option to even do so. It wants you to set up channels. My router isn’t close to my antenna so ethernet + antenna isn’t an option. I somehow manage to get my phone app to get to a wifi set up even though most of the time it still requests that you switch to the Tablo_XXXX wireless network (which, in case you forgot, does not work). But now I am on the page to set up the wireless credentials? Does it scan for available networks? Nope. Fine, I will enter my SID and password manually. Hey, it works! Move it back to the antenna, scan for channels. Tablo crashes mid scan and I can’t connect to it anymore. At all. This includes ethernet.
Factory settings reboot! Still can’t connect to it by any means. Go to bed. Next day I can somehow connect to it through ethernet (I think this is having it unplugged long enough). Go through same crazy setup to get my wifi SID and password put in. Now Tablo stops broadcasting wifi and won’t connect through wifi at all. Ethernet also goes out again.
I will call their support line. I don’t go into work in the morning. On hold for 30 minutes. That’s fine, they are specialists and are busy with other customers. Get ahold of one of them. Start working through an issue. Phone line drops. I don’t have time to wait in the queue for another 30 minutes. Would be nice if I had set up a way to get back in contact with them directly in case something like this happened. Lesson for next time. Maybe I can email them with a request saying I got booted off a call and it would get answered. It’s a shot in the dark, but who knows. Nope, I just get a snarky response back hours later saying they are busy and can’t call me back. Pretty sure my email was not understood.
I get a chance to leave work early so I can call them before their 5:30 closing time. It is a well advertised closing time. Snarky email told me when the closing time was. Wow, I made it, 5:23. I call. “Our offices are closed.” Now I have missed 2 hours of work for no help. Sure, I get that people can’t work all day, but if you aren’t going to answer phones at 5:30 THEN DON’T SAY THAT CALL IN SUPPORT IS OPEN UNTIL 5:30!!!
I am fairly certain I have bad hardware. I want to go through the correct channels to get it fixed but Tablo seems intent on making sure that getting help is a giant waste of my time.
