Does anyone who has a TCL Android TV running Tablo’s application on it experienced disconnect issue with Tablo every time when you turn off the TV? I will have to reconnect with the Tablo every time I turn on the TV and launch the Tablo app. I have noticed that TCL Android TV when turned off the network port and USB port are off as well.
I have a TCL 55R625, and the Tablo app works just fine on it. You might check some of the TV’s network settings. Other than that, I have no clue what the problem might be.
Something I just thought of… in the TV’s Power settings there’s an option called Fast TV Start. If that’s set to off, the TV is probably shutting down the Wi-Fi connection when it’s powered off. In that case, it would need to re-establish the connection when turned back on.
Turning on Fast TV Start should keep things connected.
Thanks, Jack! My TCL Android TV doesn’t have the fast TV Start, but it does have auto start on Chrome Cast. I have turned that option on to see if it keeps the ethernet port powered when the TV is off.
Duh. I saw “Android” and read “Roku.” Never mind.
