I used same settings as 2 tuner: Ethernet. I can see everything in the Tablo App. On FireStick 4K, message is “Connecting to Tablo…”
Same message after rebooting TV and Tablo units.
Help!
Help!
Hello and welcome to the Community. Has your issue been worked out? If not, please try rebooting your router, too. Then clear your device cache following this article.
Are you running 2-tuner and a 4-tuner side-by-side, or did you replace one with the other?
I changed to a 4-tuner. Ultimately, I uninstalled the TabloTV app and reinstalled. All good now.
Glad you got it working.
