I have 2 Tablos, each with its own SSD. #1 is for daily use with a lot of recordings, #2 is set up to record several TV shows for an archive. I check the recordings on #2 every week or two, then switch back to #1.
Every few days I will start up Tablo #1 (or so I thought) and to my surprise my regular daily shows are missing; what has happened is somehow tablo 1 has switched over to tablo 2, with no action on my part. Of its own volition so speak. It’s a several step process to switch over from 1 to 2 when I manually do so. I’m wondering how and why the tablos do the switch on their own, with no action needed by me?
I have only ever noticed this autoswitch form 1 to 2, not the other way. I switch over to #2 only every week or two, just briefly to make sure the archive is being filled.
Well I did the renaming last week and this morning my setup had switched itself again. When I started tablo it opened to my secondary unit. Also generally running very very slowly.
There was a message popped up on the screen “error occurred” and telling me to call CS if it persists. I close tablo, try again, it works better, but very slow. I have no time or motivation to call CS.
Another day in tablo land
