Sideloaded FireTV Tablo App is up and running again too… seems to be working flawlessly.
Support had me delete shows so the drive is less than 80% full and it's now working again... So apparently there must be some reason the auto delete feature isn't auto deleting... :D
So you can’t use a full 2T drive, must leave what, 200G or so unused?
@JerzWhere did you get the Tablo APK to sideload to the Fire TV? Thanks!
I added the chrome extension ‘apk downloader’ and then downloaded the apk from play.google.com using the chrome browser.
Support had me delete shows so the drive is less than 80% full and it's now working again... So apparently there must be some reason the auto delete feature isn't auto deleting... :DSo you can’t use a full 2T drive, must leave what, 200G or so unused?
Well I can’t… I’m not sure about anyone else but I wouldn’t think you could use the entire 2TB without issue based on my experience. I’m sure the Tablo team is working on a fix.
@Jerz @ShadowsPapa Quick correction on may part! Auto-delete follows this rule:
4 hours of recording time depending on your current recording quality, times the number of tuners the Tablo has.
