I’m putting this in General because I don’t want support or to troubleshoot, but I can put it there if it needs to be, I just wanted to see if others had this issue or if Tablo knows about it.
On a couple occasions the guide is not up to date. I.e. there is a football game on, but the guide says it’s regular programming. If I click to watch that channel an error pops up and says the program can’t be played. There is a dialog with retry or exit Tablo. If you click retry the broadcast displays for a split second then goes back to the error. If you click exit Tablo it exits obviously. Why can’t Tablo just play the channel as-is even if the guide is wrong? Seems kind of dumb. I just exit Tablo at that point and just watch through the TV losing the ability to pause, etc.
