Tablo won't connect with Safari on MacBook Air
Can’t connect to my Tablo with Safari Version 17.1.2 (19616.2.9.11.12) (preferred browser) but works with Chrome. Just keeps coming up with the home page and the Search Again button. Clear the cache and restarted the computer. Everything is on the same network. Are there some default setting in Safari blocking the search?
Solved: Safari has a privacy setting that prevents trackers and websites from knowing your IP address. This stops Tablo and Safari from connecting properly.
so how and what do you turn off?
In Safari, go to Settings and uncheck Hide IP address.
I don’t see how you can use Tablo on browser. What’s the web address?
Probably talking about the OG Tablo units, not the 4th gen one you can currently buy.
Ah, thanks.
