Tablo wont connect after internet outage
Lost internet service for a day and a half and now the Tablo won’t connect. I’ve done all the troubleshooting. Please help.
It would help if you included which version of Tablo you have… Gen4 (the round white unit) or one of the Legacy units (usually a square black box).
In my experience with the Gen4, a simple reset (a quick press of the small button on the bottom of the unit) usually does the trick. You could also just unplug it for a minute. DO NOT press and hold that reset button as you could perform a factory reset and have to start all over.
If that doesn’t work, I then also reboot my router. Lastly, since initial setup is done on the phone app, I use the phone app to try and reconnect. I find it is slightly more reliable. Once the phone connects, all my other devices connect.
Best of luck, and let us know how you make out.
Ken
@chefchadself
Tablo Legacy or 4th Gen?
WiFi or Ethernet?
If other devices are connecting to the Internet then first pull the power plug on the Tablo, wait 30 seconds them plug it back in. Wait till it boots up then check the settings in the app on your phone, tablet, or TV.
If the settings in the Tablo are correct look in your router settings to make sure no setting was changer because of the outage like WiFi SSID or DHCP settings.
If all is good reboot your router and check all the settings.
