New tablo user (in fact evaluating). Everything seems to work okay until I want to change channels. Then I get stream error on either client (roku 3 or Firefox). If I go back to original channel works fine again. If I reset tablo, the first channel I choose is the only one I can access.
@tablosupport, Any ideas why the channel changing function won’t work? thanks! I think I also submitted a ticket though I have not heard anything.
@dcon1138 Do you have a hard drive attached?
I don’t see anything on the support system from you - did you send it from your current email address that you’re using here?
@tablosupport Hmm… I thought so. I can try again if you suggest. thanks!
@tablosupport I submitted the ticket. Please let me know if you don’t get it. Also the HD seems to record okay when using the pause function, play functions.
@dcon1138 Ticket received
