Tablo will not start - SSD really the issue?
A few days ago, my Tablo 4 Gen will not start. I reached out to Support and they had me
  • Unplug the external hard drive
  • Unplug your router/modem from the power for ~15 seconds and then plug it back in again.
  • Once your router/modem is fully rebooted, do the same with the Tablo.
  • Keep the external hard drive disconnected
This got the Tablo operating again. So I reattached the hard drive and everything worked… for a day or so. Then Tablo would not start… again.
Support wants to blame the hard drive. It’s a solid state drive, so I doubt that’s the problem.
Anyone run into this issue? Any solution? I think it’s a bug in the software?
@TabloEngineering @TabloForumAdmin @TabloEngineering
Weak power supplies are often the issue with external drives powered by the Tablo. If the supply is bad enough, even an SSD may cause problems.
Even though the drive works, it is possible it could have some internal problem. However, a weak power supply could be the issue as already suggested.
The power comes directly from the Tablo unit. No other source of power.
@andyross @mbellaire
@andyross is referring to the power supply for the Tablo itself.
I remember there was speculation in this thread about self-powered drives maybe working better because they didn’t draw power from the Tablo USB. It could be possible that certain USB-powered drives cause issues by drawing more power from the USB than the TabloTV can provide.
What’s the bottom line here? My SSD drive has one USB connection. And that goes to the Tablo directly. So this has been my setup for a year now. Why would the drive occasionally cause an issue now? I’m searching for another potential reason for this situation. First thing that I think of is the latest update by Tablo.
Just providing hard drive info. Disregard if it doesn’t apply. However, Tablo Support says it’s the hard drive. Did they happen to provide you a reason why the drive isn’t working or a solution? Is the drive on the list of supported devices?
SSDs do sometimes go bad, and often with little or no notice. Which SSD are you using? I have this Western Digital and (so far) I have had no problems.
Silly question, but have your tried replacing the cord? Make sure you try a good high-speed cord.
Seagate BUP Slim BK0304 1 TB, operating flawlessly for a year.
Perhaps this is one of those Dicey Drives as described in #4 of the Tablo blog article shown below. This link to the recommended list of drives taken from the blog doesn’t work.
I have been using the San Disk portable USB ssd’s sold by costco. one 4 TB and one 1 TB.
Working OK, but it can take a second or third try to delete items. I don’t know if this is due to the way these ssd’s work, or the tablo app, or both.
I have a 3.5 Western Digital Black 4TB (I had one sitting around) with a ghetto Amazon USB adapter with a power plug… and its been chugging along.
I have a WD 2TB SSD. I have noticed that sometimes when I delete a program (especially if I am doing a “Delete All Watched”) that it take a moment for the program(s) to disappear from the list. The first few times I tried to delete them again, multiple times. Eventually, I realized it I waited a few seconds, they would disappear, certainly if I exited that menu and went back in to check.
Yes I’ve seen the same behavior. I’m still not convinced that all this is tied to a hard drive though. In the last day or so I have not been experiencing the problem anymore after talking to support on the phone, which seems to get a little faster help than on the community Forum here
Sometimes even go slow is too fast.
Just something to be aware of and live with.
