Should my Tablo dual wifi work with my LG smart TV using either my iphone or android hotspot. Works fine on the phones but doesn’t show up on the TV.
Is your TV on the hotspot? Can devices see each other on the hotspost?
From https://www.tablotv.com/blog/tablo-faqs-do-i-need-internet-use-tablo-ota-dvr/ scroll to
Why Cellular Data and Mobile Hotspots Are Not Recommended
Long story short, your Tablo OTA DVR is designed for cord cutting homes with WiFi-enabled routers and a consistent, high speed connection to the internet. If you don’t have internet access, or use cellular data and mobile hotspots, Tablo is not recommended for you.
But there are post from TabloTV where they say it does/might work.
