I’ve been using a 4-tuner fourth generation Tablo TV for about a week now. Generally, I’m happy with the experience so far. I previously listed two areas where there is room for improvement. However it turns out that I was able to solve BOTH problems.
First, the aspect ratio problem I reported only happens with a very specific set of circumstances: The Tablo app must be loaded as an app on my Roku TV. On the other hand, if I load the app on my Roku Express, or if I open the app on my phone, the aspect ratio for the 480 stations is perfectly fine. In addition, on my Roku TV, if I open Roku’s own Live TV rather than the Tablo app, the 480 stations also look perfectly fine, in 16:9! So the Roku TV sees the 480 stations correctly, and Tablo sees the 480 stations correctly on a Roku Express or an Android phone. The ONLY circumstance where there is a problem is if I’m using the Tablo app on the Roku TV; very odd! Now is it possible that there’s something that Tablo can fix regarding its interface with a Roku TV that isn’t causing a problem when loaded on a Roku Express or an Android phone? Perhaps; maybe Tablo could look into that.
The other area where I encountered a problem was the number of series episode recordings to keep. I could not find a place to specify that. Fortunately, thanks to Scandy and KGBnut, I was able to locate the menu where that can be determined.
Thank you for your attention. I think I’m all set, and I’m now going to be able to save over $1100 a year! Interesting discovery. I had been limping along with a Channel Master antenna DVR, and my reception was so awful I was forced to subscribe to a live TV service. After getting a new TV last week, I discovered my reception was much better than I’d previously thought based on the Channel Master DVR. So, after years spent without, I switched to Tablo and suddenly I can now receive and record all of my major local broadcast channels!!
Before anyone concludes this is a Hate Channel Master message, the fact is that I’m getting this very good reception with the Channel Master Smartenna, an ingenious device, the full utility of which I was never able to appreciate until I got the Tablo, because of the Channel Master’s DVR wretched signal processing. I just wish I’d discovered the Tablo years ago!
