Can a WD 4TB My Passport Portable Gaming Hard Drive be used with a Tablo SPVR4-01-NA? I see that the gaming HD is less expensive then other HDs. Thanks in advance for your help.
I use this 5Tb one, only $100 and more storage than we probably will ever need.
Thanks for your reply. That would also be my choice of drive. The WD Elements drive usually sells for around $100. I have seen the gaming WD passport sell for less then $50. If the passport performs similar to the elements why pay more?
