Are the Tablo authentication servers down today, May 7th, 2024. I can not connect via the Windows app, or Android app. Roku also appears to be unable to authenticate.
What’s happening?
What’s happening?
Hi there @jimzix Guessing you’ve got a legacy device given the Windows app mention.
Everything is A-OK on our end so it sounds like your Tablo might be offline?
Is the blue light solid?
These steps should help you get back up and running, but if not don’t hesitate to touch base with support:
Ditto the problem with the Roku app for a while this early evening, about 6pm. Live grid was completely blank on all channels, and date on the grid was set to Dec. 20 (on May 7!). Don’t know how long this condition lasted, but it is now–at 9:00 pm–back to normal.
Actually, at 6ET Roku was having an issue and it was reported on their web site. I was trying to activate an Ultra which I factory reset and I couldn’t get past entering my email address. A little after 7ET they were back up. The Tablo Roku app issue was not a Tablo issue but a short Roku outage.
Thanks for the explanation.
