Some time ago I had uninstalled the preview channel while troubleshooting the rebooting problem and decided to reinstall it and see how things go. (Btw no reboots since deleting it.) On my first attempt to use it I selected recordings and was scrolling down through the recordings and it closed out and returned to the Roku main menu. I tried two more times and the same thing happened both times. It does seem the speed at which I scroll determines how fast it closes but so far it’s closed out every single time. Haven’t located another thread with a similar problem. Wondering if anyone else has experienced this or might have some insight.
I just tried to open the chrome app on the laptop to see space used on HD and being told there isn’t a Tablo on my network. I am however watching it via Roku as I type this. Bizarre. But usually there is about 700-800GB free on a 1TB drive if that helps.
Also, just learned the laptop I was using to access my Tablo last night to determine info for theuser86 was using a VPN so ignore that little non-problem. Sorry about that.
