I have no issues, just curious where my 3 wireless Rokus are getting their Tablo signals from. I have my indoor flat antenna to Tablo wired to access point router in a separate detached room. Access point is wired to my main house router, 2.4ghz and 5 ghz channels on same ssid.
Main TV is Roku Ultra connected to 5ghz network. I assume it’s getting its data from my main router close by.
The TV in detached room has Roku Stick connected to 2.4 hz channel from access point. Both routers and both channels same ssid.
How does the Tablo know what it’s connecting to? Just amazing that this thing actually works on both TVs at once. Any speed help (changing channels) moving the Roku Stick by the Tablo to the 5ghz network? I’m not sure if that router is set up to output 5ghz, just wondering if it’s worth checking (Linksys wrt54g).
