Tablo Ripper won't Start
@CycleJ
Win 10 64GB
Ripper v 2.4.1
Hello
I haven’t used the Tablo Ripper for awhile.
Tried to Open it today, Just spins, “not responding”.
I can’t click on anything, Window to change the IP Address, log file etc.
My default Tablo IP Address has changed since I last opened the Ripper, think this might be the problem.
I tried uninstalling/reinstalling the ripper, but it remembers the old/incorrect IP address.
Is there a ini file or something similar that I need to delete, so the ripper starts fresh looking for my tablos?
Thanks
Chas
It will time out if you’re patient. But if you’d like a fresh start, the data is stored under a hidden Windows directory named “c://ProgramData”. Delete the TabloRipper folder you find there and you’ll have a fresh start.
@CycleJ
I deleted the folder.
All OK
Thanks for the prompt response.
Chas
