Tablo Ripper won’t connect, I get a dialog box that says “exception the underlying connection was closed: an unexpected error occurred on a send.” HELP!!!
I am having the exact same error now. Worked pefectly last night, please help.
try posting in #tablo-apps > #tablo-apps:third-party-apps-plex tablo ripper isn’t an “official” tablo app and/or product
I am having the same problem - Tablo Ripper just stopped working yesterday, May 30th at approx. 14:00 EST. Tablo running 2.2.28. Attempted soft and hard reboots of both the TABLO and my Router with no luck. Uninstalled<>Downloaded a Fresh TABLO RIPPER 2_4_1<>Reinstalled Ripper. Still Ripper can not find my Tablo when launching. and got the same notification as before: "exception the underlying connection was closed: an unexpected error occurred on a send.”
Access to TABLO seams fine with both the PC Apps and multiple ROKUS on network. NOTE: I did however lose all scheduled recordings.
As a workaround for now, if you specify the IP of the Tablo it will connect.
Isn’t that more “as designed” alternative than a workaround
Sure, we can go with that.
It’s always been an alternative but it’s also a valid workaround for people who don’t usually enter the IP to be able to have Tablo Ripper connect successfully to their Tablo.
I’ve had the same experience of being disconnected around May 31st, 2020, and the same success in reconnecting my using the Tablo IP address.
IP address worked Thanks
It’s fixed, please download the latest version.
