Is there any way to search through shows? If there is not please consider this a feature request. It’s starting to get a little difficult as my recording library expands.
How are you using Tablo Ripper? If you are using it to pull content off the Tablo is there a reason it needs to be kept on the Tablo as well?
I don’t pull everything off the Tablo. I only grab things I want to archive.
Are you then having it delete the items you are archiving and even then the list of remaining items is just too large?
Yes, when I archive something I usually remove it from the Tablo.
EDIT: My Tablo has a 4 TB drive. I have a lot of shows on there.
