I know this topic has been covered before but cannot seem to get it to work. Tablo is no longer available remotely which is the reason we invested in the box years ago since cutting our cord. We recently changed our IP provider to Starlink, which we know uses CGNAT and different protocol than port forwarding. I have read from many users that a solid work around for many users is Tailscale. I have gotten Tailscale to work remotely reaching my NAS home servers, but cannot seem to set up remotely reaching the Tablo.
Here is our setup…
Starlink > Raspberry Pi 3 set up as an exit node and subnet router (same IP address / range the Tablo is running) running Tailscale. I have read success for other users going through this process. We have not been successful.
Tablo Device: 2.2.42
HTML Application: 1.9.9 build 227
Host Application: 1.909.227
Server host: 192.168.1.***
I feel like something in the exit node, subnet routing might not be right in our setup. What IP address should the RP subnet be? It is set up now to be 192.168.1.0/24. If not right, what should the IP be? The IP of the Tablo? IP of the PI? IP of Starlink?? And when those settings are right should we be able to access the Tablo just by opening the app? Or is access to the Tablo remotely another way for this Tailscale setup?? As I understand it, the Tablo should run as if on the LAN just by opening the app because of the exit node/subnet router. (Should both the exit node and subnet router be set up in Tailscale to accommodate the Tablo? Or one or the other but not both??)
Any help would be greatly appreciated.
