My Tablo Quad OTA was delivered to me without a hard drive enclosure screw, so when I move the unit, the enclosing plate just falls off. I have to imagine that the screw is a fairly simple thing to replace, so if someone could please describe it for me in a way that I can find a replacement at my local Lowes, I’d appreciate it.
Have you contacted @TabloSupport to see if they’ll send you one? I’m guessing that would be simpler than blindly looking for a replacement screw.
It’s an M2 x 6 but we’ve got a supply at HQ and can mail you one if you touch base with support:
