Tablo Quad cannot be found on network, also says Tablo not broadcasting Access Point.
Tried reset button light stays solid blue, Blue LED does not flash at all.**
Using Fire Stick.
Pulsing –If your Tablo is using firmware version 2.2.26 or above, its blue LED will pulse when it is ready to be added to your Wi-Fi network. (This blink is not present on TV-connected DVRs like Tablo DUAL HDMI)
Without a network cable plugged in, tablo uses wifi. It’s blinking waiting to be configured to your wifi network? which may be why it can’t be found.
Getting Connected to Tablo - https://support.tablotv.com/hc/en-us/sections/200278929
