Tablo Port Forwarding
Goto http://www.canyouseeme.org/
This site will show your ip address assigned to you by your service provider.
In most cases this ip address can change ever 1 - 12 months.
You can also port check from this site.
First find out what your internal router ip address is?
my router ip address is 192.168.1.1 linksys router Other router have different numbers
My tablo address is 192.168.1.112 this number depends on router
If you goto your explorer or chrome browser and
type in (your device ip address) 192.168.1.112 it should say
Tablo Server if you ping the tablo
To find your ip address download and run IP Scanner
It will show your device ip address.
Some times you can get this from your router
Your router assigns ip address to devices find out what the ip of your tablo.
When i click on remote access in settings
It said manual config and it gave me number to port forward
21131 to 8887
21130 to 80
Tablo external port 21131 internal port 8887 both tcp/xxx 192.168.1.112
Tablo external port 21130 internal port 80 both tcp/xxx 192.168.1.112
Save this in router and my tablo said.
Your Tablo is ready for remote access.
Enter what your tablo says to port forward not what you see online. search for your router port forward on www.youtube.com
