I’ve been using my Tablo 4 tuner more than typical due to the Olympics. I’ve noticed that the Tablo will have incidents where TV suddenly pauses and then after a minute or two it resumes. I noticed the problem seems to be worse with 1080 recording at 10Mbps.
My network is great. Iperf wireless at 300+ Mbps on 5ghz and 90+ on 2Ghz throughout my house. I also used a cat 5 connection to see if wireless for some reason was a cause. The same issue occurred when wired.
HDD that is on the recommended list.
I did a factory reset and issue still persisted.
I only had 1 channel recording, NBC.
It seems the issue goes away when set to 720p. However, I do notice TV pause for a second when I opened the iPhone app while playing on my AppleTV.
Can the Tablo simply not drive the 1080 recording with 1 TV playing.
