I just purchased a Tablo Quad with 1TB internal drive. I was a little nervous about the temperature it was running at, close to 210 degrees. My solution to this problem was to use an external cooler designed for laptops. Now the Tablo is running at 75 degrees. Hopefully, the unit will perform more consistently and have a longer lifespan. The cooler is available thru Amazon and is not that expensive. A bonus is that the fans light up in a complementary blue color matching the Tablo’s blue led.
