Tablo or Roku 'wired'
Quick question. Which would be better to have ‘wired’, my Roku or the Tablo? If one had to be be wi-fi and the other could be wired.
Tablo wired. As it can serve multiple devices better over wired.
Personally I would wire the Tablo because if you use more than just the Roku to access you will get more bang for the buck.
Thanks guys. That’s what I figured.
