New MacBook Pro laptop with all the updates. Tablo works fine in Chrome. In Safari, Tablo loads, shows all my recordings, shows the live TV lineup, but when I click on anything, I get a place-holder screen and it never plays. Any ideas?
@MarkPekala I’m running on the same specs without any issues. Do you have any extensions/add-ons enabled in Safari? If you do, can you try disabling them and re-trying this? If not, try deleting the Tablo from the http://my.tablotv.com/ portal and re-syncing to it.
On a mac mini at 10.11.6 with latest safari and chrome browsers and both work fine. I don’t use them much for Tablo, but after a long sync ~2 mins they both work fine. Tried thumbnail forward and 30 sec and 20 sec as well as the dot bar and all worked just fine. I also tried Firefox and it found Tablo ok but never did complete the sync.
