I have tablo 4th gen and roku ultra. Ive installed tablo thru android phone
On roku home.i pick tablo app, it says tablo not connected to internent. I go back to roku home and pick tablo tv, i get the tablo channel
Is this the way it should be? Will i be able to record roku channels?
Also when i pick a tablo tv channel and select record the series shows that it will record
Is it really recording
The white Tablo app is for older devices.
The blue TabloTV app is what you need for a 4th gen white Tablo.
You can look at your Scheduled section in the Library to check upcoming episodes, or look at the live grid to see what is showing there.
