So, there are multiple posts and even a blog post about how Mesh networks are bad and Tablo isn’t compatible with them. I have multiple streaming devices and servers connected via wifi to my mesh network with zero issues. I throw Tablo up on my network and goes nuts. Tablo is bouncing between access points like a Mexican jumping bean. How about fixing the wifi driver in the Tablo so it doesn’t jump around so much instead of just saying it’s not compatible.
I was able to fix this by running an ethernet cable from one of the Access Points to the Tablo. Everything else has stayed wifi and the Tablo has been rock solid. Just sad that this has been the fix. I had to move one of my Access Points to a less than desirable location to provide an ethernet port for the Tablo.
