I’ve had an issue crop up a number of times but I haven’t messed with it to reliably determine what’s causing it.
@stevebob Hm, that’s certainly odd. When you say that it becomes unresponsive, does it respond to the reset button on the back at all? Or do you need to pull the power from it? If this happens again, feel free to send me the details in a ticket and we can take a look around.
It responds to the reset button on the back (this is how I’ve been resetting it) but is unresponsive to any form of connections (ipad, web, roku).
I am experiencing a similar problem. Was hoping to see the resolve for @stevebob. Differences are:
1. dual tuner (wireless)
2. Roku 3
3. No powerline
4. I can not reset the Tablo with the reset button. Must remove power, wait 30s, power up.
@WildBill - your situation may be different so recommend that you contact TabloSupport so they can pull logs from your Tablo.
@Mark @TabloSupport
Thank you guys, I have contacted TabloSupport (wow, fast response). They are working on it as we speak.
My problem still exists. I now have a new issue of constant buffering on my roku. The issue began after the most recent update and makes watching impossible sometimes.
