Tablo, while we wait for your Fire TV app, can we have the APK for the Kindle app so we can sideload to Fire TV. Thanks.
@hdmkv
What I’m having trouble with is downloading the APK. Tried http://apps.evozi.com/apk-downloader/, but not letting me grab.
Use this in your Chrome browser on your computer:
https://chrome.google.com/webstore/detail/apk-downloader/cgihflhdpokeobcfimliamffejfnmfii?hl=en
Your Device ID may actually be your GSF ID.
That’s the issue - unless I have a device registered that will handle the apk file, Play won’t let me download. It says no compatible device or words to that effect. Amazon is worse, but play can be nasty when trying to grab things it “thinks” won’t work for you.
If you have any Android device, either a tablet or a smartphone you can download the Tablo Web app APK from the Google Play store.
Only have Amazon Kindle HDX, so don’t think it has the necessary ‘Google’ device ID. Thanks for your suggestions though.
@hdmkv
Do you want the android tablo app?
http://www.1mobile.com/tablo-web-2386355.html
Tom
Download from those sites at your own risk. I would only trust the Google Play store.
Guess people are getting desperate for a Fire TV solution.
Absolutely. I only use 1mobile if needed plus you can also scan it on virus total for android malware.
Thanks guys. Just need as a stop-gap as hopefully the official app will be out this quarter as indicated.
