Next week, the hardworking team at Tablo HQ will be taking a break to spend time with our families.
However, a limited crew of support gurus will be available to assist customers with any pressing issues.
Our holiday support hours will be as follows:
- December 25th - CLOSED
- December 26th - CLOSED
- December 27th - 9:30 a.m. - 5:30 p.m. ET
- December 28th - 9:30 a.m. - 5:30 p.m. ET
- December 29th & 30th – closed for the weekend as usual
- December 31st - 9:30 a.m. - 5:30 p.m. ET
- January 1st - CLOSED
Response times over the holiday break may be longer than usual, so your patience is appreciated.
We will resume normal hours and staffing levels on January 2nd, 2019.
As always, if you have a question about using Tablo or if you need some assistance, you’ll likely find the answer via our How It Works page.
Still puzzled? TabloTV.com/support has quick links to key resources like quick start guides, troubleshooting tips, and more.
And of course, you can always search or ask the helpful folks on the community forum!
Happy holidays everyone!
