Do you have enough server horse power to handle increasiing loads on your servers in the evenings? I’m sure your customer base has increased over the last 8-12 months. More people would be trying to log in for evening viewing. Are you accurately anticipating server needs for this ever increasing load?
Almost every day now at 6pm, I have to try at least 3 times to get Tablo Gen4 to load up to view TV. Are you keeping up with the actual customer load to provide a good customer experience?
You mean all of those 10’s of millions of people that live in the Eastern Time Zone are affected everyday at exactly 6 PM. Wouldn’t it also affect the millions of people that live in the Pacific Time Zone but at 3 PM?
There seems to be an issue with the apps where each hour change can cause the device to glitch. Best temporary solution is to open the app a couple minutes earlier.
As our user base has grown, it has certainly put more of a load on our servers, but our team has been and will continue to be hard at work to ensure we scale as efficiently as possible.
Any plans to make the 4th gens less internet-reliant? This would take the pressure off of your server at those hour changes and likely help increase your user base.
@TabloTV thanks for that feedback. I can certainly see the impact of your increasing user base and the load issues that have occurred in recent months, particularly in prime time.
The key is staying ahead of the curve. Good luck and (again) thanks for the feedback.
Just how much guide data is kept on the Tablo? The old ones only update overnight. Don’t remember if it survives a reboot or is stored on the drive or some NVRAM.
It sounds like the Gen4 only hold a few hours at most? Or is DVR scheduling also server based (like Comcast X1)? If the load is due to updating the guide every hour, then maybe expand how much is held. The servers could assign each device a window to next update, based on expected loads, to prevent slowdowns.
You mean you don’t find it exciting to click on a FAST channel show icon and have it appear to be searching the universe for the data. When in reality it should, in the worse case, be on the actual tablo unit.
