Jestep - here’s some further observations using your cool exporter for a while.
Whenever I do multiple export I still get a false “completed” show at the beginning of the export queue. My workaround is to immediately cancel all, clear the queue menu and click export again - everything’s fine after that until I select and export another batch of multiple export shows/programs.
No error messages, just a quick “completed” Status of one program that’s not really completed.
Something else I noticed today after spending the past couple days deleting unwanted shows/programs in Chrome browser. I can see several older shows/programs deleted via Tablo Chrome browser GUI still showing up in Video Exporter. Weird?
I dunno if the files are really there or not? Maybe I should try exporting one that I know has been deleted in Tablo GUI and see what happens? I’ve gotta batch shows exporting at the moment but I’ll check when it’s completed and report back.
Thanks again!
EDIT to add - Oops, shows I thought had been deleted were actually still there. I was looking on Tablo recordings page and relying on the little number in the upper RH corner of the show picture. There were shows inside the folder that had been mark by Tablo as watched. Please ignore 2nd part of my post.
I have seen the first thing you mentioned and I think it had to do with the queue reloading. But I need to investigate further, just haven’t had the chance. Thanks!
I finally got the exporter working. I am missing several shows that I would like to export. Shark Tank and Late Show with David Letterman are not showing up in my list but you can clearly see them on the Tablo FireTV app in the pictures below. Shark Tank Episodes are not protected and the Late Show episodes are. Any plans to add the metadata to the files?
If you run from the command line you should be able to see the http call to get the show. This will help trouble shoot. Can you check that for Letterman and shark tank?
I had exported that Charlie Rose episode before so that may have been the issue i experienced. I am exporting a Letterman episode and it looks like it’s all good so far. I’ll let you know what shows up in MetaZ.
FYI, I just tried MetaZ on The Late Late Show With James Corden and MetaZ shows nothing however in VLC Player it shows the title and Description (Comment)
I am wondering how it actually works…
Just installed this latest version (0.02d?). It would start for me on my Windows 7 x64 laptop. Once I switched back to version 0.02c everything is working fine. Haven’t changed anything else.
