How do you determine the amount of storage space used for your plugged in hard drive? Can I find out either by percentage used/remaining, or MB used/ remaining?
I don’t have an HDMI unit but if it’s like the network units you can go into Settings and there is a Storage section that will show you the capacity of your drive and how much is available.
Thanks, I appreciate your response; I’ll try that
Another way… Open the Tablo app on your smartphone, go to settings. There is a section there called “Storage”. You’ll see that info there.
Smartphone app doesn’t work with the HDMI units.
“Due to technical limitations, TV-connected Tablo DVRs cannot be accessed via:
- Apple TV
- Smartphones or tablets
- PC/MAC
- Smart TVs powered by Samsung TIZEN or LG WebOS
- Xbox
If streaming to these types of devices is important to you, consider a network-connected Tablo DVR instead.”
This is in the SETTINGS screen:
