When I got my Tablo I originally set it up with an ethernet cable. I’ve decided I would like to move the device and connect it to my home WiFi. I took the following steps:
Disconnected existing cable
Performed a reset of the device
Opened the Tablo app on my phone and selected “Add via Wi-Fi”
Connected to the “Tablo_****” Wifi network and returned to the app
At this point I see a “Choose Wi-Fi Network” screen with no WiFi networks available:
I click on the “Rescan” button and get stuck on the following screen indefinitely
Any hints on how I can get this device to find my home Wifi? I have the device sitting in the room with my router which is running a WPA2-PSK secure network. I’ve also tried entering the information manually with no luck.
I have not tried rebooting my router, but I don’t believe the router would be the issue. We have quite a few wifi networks in my neighborhood that I can see, but the Tablo doesn’t see any. I can give it a try, though.
Nope, the network is not hidden. It’s a TP-Link AC router broadcasting both a 2G and 5G network.
I just got it working. Here is what I did in case any one else runs into the same issue. I again reset the Tablo and opened the app and selected “Add via WiFi”. I then connected my Android phone to the “Tablo_****” wifi network and returned to the Tablo app. I noticed a notification at the top of my phone that stated something to the effect of “Internet not accessible on this network. Click for options.” I click the notification and was presented with something like “The internet is not accessible on this WiFi network. Stay connected?” I selected “Yes” and returned to the app. Suddenly all the WiFi networks appeared and I was able to select my home WiFi and connect.
