Tablo doesn't record scheduled show
A show I have recorded all winter suddenly isn’t recording. The show right before and right after on the same channel record, but not the one in the middle. It is scheduled but isn’t recording.
Hi @anij113,
What Tablo app are you using to record?
What happens if you set your series to stop recording and then reset it again?
As a temporary workaround, you can extend the recording time of the show just before the one that doesn’t record correctly. Extend the recording time to cover the length of the show that is not recording. Not the best solution, but it works.
Is this a two tuner or 4 tuner device? Did you just start to record another show at the same as the second one that may be causing a conflict?
Edit: started to start
