I just got a 4 tuner Tablo last week and really like it. Trying to add a hard drive so I can record programs. I attached a WD Elements hard drive to the Tablo box. When I go to the TABLO page of the Roku app it shows “no hard drive connected”. I had previously tried a WD My Passport hard drive with the same results. What do I need to do so the Tablo will recognize that a hard drive is connected? I would appreciate any suggestions.
Power off your Tablo by unplugging the power cord.
Connect the USB HDD.
Power on the Tablo.
Connect to your Tablo using the Tablo app on a smartphone or tablet (iPhone or iPad for example), then see if it asks you to format the HDD. Do not use the Roku.
I’ve recorded a few programs using the WD Elements hard drive and have noticed during playback that the video is breaking up. Is there a setting that can be changed to eliminate this?
What you are describing is likely pixelation of the video. This is generally caused by weak / poor OTA signal. You’ll need a preamp at the OTA antenna or a bigger antenna.
If you are seeing this issue on ALL channels then it could be do to the hard drive. I’d replace the hard drive then.
