Tablo Crashing - August 2026
My Tablo app on Apple TV (4K, 3rd generation) keeps crashing and kicking us out of whatever we’re watching.
I’ve rebooted the router, the Tablo device, and the Apple TV, but the issue is still happening.
Looking for guidance on what to try next.
Welcome to the community! Sounds like you’ve taken the proper 1st steps. Now you’ll want to ensure your broadcast signal from the towers is strong enough (or optimized) and your network between the router and Tablo and between the Tablo and AppleTV is also working well. Once these are confirmed, then repeat your original steps.
Use Ethernet wherever possible.
@Lamont_Russell
You might try deleting the Tablo app and reinstalling.
Hi Lamont,
Do you have HomePods connected to your Apple TV? There is a stuttering issue that’s linked to them, something we’re working on fixing.
If this is the issue you’re experiencing, try disconnecting the HomePods.
