I am unable to get Tablo Connect to work. I went into the Camocast cable modem and put it in bridge mode. Next I went into my Netgear R6300v2 router and turned UnP off. Then I set ups port forwarding per the attached picture.
I have had 2 Netgear routers but they were R7000 and R8500 models. I couldn’t get Tablo Connect to work on them and had no success with Tablo support when I contacted them. I work in IT for a living and configure routers all the time and am familiar with uPnp, dhcp, static IPs, dhcp reservations, etc. I ended up getting a Cisco router which worked right away. You may have other luck with this. They have a guide here: https://support.tablotv.com/hc/en-us/articles/115005962283-Tablo-Connect-and-Port-Forwarding
To confirm your Comcast modem is in fact in bridge mode, go to the WAN page on the Netgear router, what does WAN IP address start with? Does it start with 192.x.x.x of 10.x.x.x?
We don’t need the whole IP to know if it’s a true external IP. Again this is the WAN IP on the Netgear router.
I have a WAN Setup page that shows: The default DMZ server shows a 192.168 address but is not selected.
I have an internet IP address of 73.10.x.x with dynamic addressing from the ISP
I show the internet port as 73.10.x.x
I don’t see a specific setting that says “WAN IP address”
The WAN IP address would be under the Status Page on the Netgear router. But as long as you’re seeing the 73.x.x.x in your Netgear router, not on the Comcast modem, you should be in bridge mode.
Thanks very much for your help! Do you think I would be able to expect this connection to stay or does it blink in and out? I ask because I’ve seen other users say it works sometimes.
Yes, I thought I turned it off but when I went to check the next day, it appears it turns on automatically when you configure port forwarding. Yesterday, I thought I would test the connection by turning off wifi on my phone and seeing if I could connect to my Tablo via my LTE connection . I was able to. Now, I am at work and tried to connect and I cannot. It tells me to check my internet connection. I’ll have to wait till I go home to see if all is the same.
After about 7 or 8 tries at work, it finally connected. It took a while to get live tv up but it finally started and the picture seemed good. Is this typical?
It’s working so I’m leaving it alone! Yea, I tried connecting to MyTablo trough my work laptop and it won’t connect through our internal network. My phone is connected to our guest network that does allow a lot more traffic.
I just ordered an AppleTV so I can watch recordings at our shore condo while we’re away from home. I’m thinking that’s the best way to get around Roku not working with Connect.
I planned on just using my phone or Ipad to connect with the tablo app and then share the screen with the AppleTV. I was just using the AppleTV to put my phone’s screen onto the tv.
Yes, Airplay. Couldn’t remember that name. No, I got the HD version. I couldn’t justify the 4K since I don’t have 4K yet and I’m not thrilled with AppleTV in the first place. It’s good for Airplay but I like Roku better. My upload speed from my wired network Imac is 295 mbs. I’m surprised it’s that good. My Tablo is wired network also so that helps. Picture from work actually looked good but I wasn’t watching anything that was HD.
