My Tablo is working fine. My Plex server (running on a Mac Mini with Yosemite OS) is working fine and I can get every channel EXCEPT Tablo. The Tablo channel was working yesterday but today it was just hanging. Eventually, I decided to uninstall the Tablo plugin and then reinstall it. However, when I tried doing it, the installer would just hang. Occasionally, I would check the directory and would see a checkmark on the Tablo plugin, but it would not be listed on my list of channels.
It is a bug and is being fixed ASAP… Might take some time for Plex to push it though
Wow! That was quick. Thanks!
@horizonjob, thank @Davidvr for fixing fast
It’s weird, though. Working great before today. Nada today. I installed and uninstalled other channels, restarted my Plex server, etc., but no joy. The checkmarks showing that the channel had been reinstalled when it was just hanging up was a cruel tease. I love my Tablo, having cut the cord (or in my case, the line from the satellite dish) around Thanksgiving. I can still watch on the native iOS app, but I recently got a Smart TV and I enjoy watching on the big screen.
@Davidvr My situation is similar – but different. This morning I found the Tablo Channel missing from my PLEX channel list. When I went to reinstall it, I found that it was still “Installed”. I have tried uninstalling and reinstalling to no avail. The little thingy just spins and spins. This has happened in the past and I have followed board suggestions to manually uninstall bits and pieces that remain after a formal UNINSTALL. That worked in the past but no-go today. Obviously, I need some more help! Thanks in advance.
@JohnT it is the same issue… The bug is causing it
I just checked the Plex github, Davidvr’s pull request has not been done yet so you will have to wait until they do it.
So I have the same problem I restarted my Plex server and the Tablo app is no longer there, will it return to my channels automatically after the update is fixed? or do I need to do something different?
I think we’ll just have to wait and see. I did several attempts to reinstall. It’s uninstalled now, and I will wait until I hear that the fix has been implemented before trying another install.
Not to sound like a broken record, but wouldn’t a native smart tv Tablo app be nice?
@mb190e yes it should
@jestep thanks, I also noticed a couple other channels are not working properly ABC and CBS lets you can navigate all the way to the show, but when you click play gives you an error.
@mb190e I tried ABC right now and I did not see an error, but when I click play it comes right back. Looking at the log for ABC I saw this on one show… But others played ok.:
@jestep yeah I tried a couple other shows and it seems to be working
@horizonjob Native apps would be really cool, and i’m sure they are on the radar. I very thankful the web app works great on my new LG, so much so I haven’t even hooked back up my roku
No completed pull request yet, looks like we’re f’d for the weekend.
I was wrong - the pull request was committed 2 hours ago - it works well folks.
