Hi folks -
An update for the Apple TV app for 4th Generation Tablo devices is now available.
This update includes some small but helpful fixes so make sure you update to this new version if you don’t have automatic updates enabled.
Here’s what you can expect:
Tablo Apple TV App (4th Gen) Update (v. 1.8.1)
- Fix for issue where the app could abruptly return to the Home screen shortly after launch
- Adds support for different PLAY vs. SELECT/OK remote control behavior on recordings
About This Release
Last time around we added the ability to hit the PLAY/PAUSE button to immediately start playback of live programs, and bypass secondary scheduling/program info screens.
You can now also use this shortcut on recordings! Enjoy.
