Tablo app won't load on Roku unless I delete and reinstall
4th Gen Tablo, Roku Ultra, both updated with latest firmware and OS. I have the audio compatibility mode set, so at least my new recordings will play back.
BUT…
The Tablo app won’t start up properly (it spins on the loading screen) unless I delete the app and then reinstall it. I can exit and restart the app within a short period of time, but after a longer period (e.g. overnight) it will no longer load again. Delete the app, restart it…and it works. Until the next time I try it.
I’ve got audio on the Roku set to Auto but I also tried Stereo. I also have digital audio format set to custom with Dolby Digital only (no DTS).
Having to delete and reinstall the app every time is obviously not a long term solution. Anybody have other ideas?
Do you use the back button until it asks you if you want to leave Tablo? If not,it tends to confuse it.
Now even deleting the app doesn’t work. And no, I tend to use the Home button to go back to the top. But how can I exit properly when it won’t even start now?
Try rebooting the Roku. That should clear up the cache.
If you just use the home button it tends to leaves portions of the app in memory and causes problems when you want to restart the app.
In addition to rebooting the Tablo and the Roku, if you haven’t already try rebooting your router. That often fixes problems like this.
Rebooting the Roku didn’t work. Trying the app on a Roku where it had never been used also didn’t work. I had to reboot the Tablo.
I would understand if the Tablo app was not working on all devices, but it was fine on my iPhone and iPad. So, it’s specific to the Roku connection. And all the stuff about rebooting the Roku to clear the cache…why should that be necessary when literally no other app on my Roku has this issue? Why should the Home button somehow cause a problem for Tablo’s app but not for any of the other ~15 apps on my Roku?
Those are rhetorical questions/rants. It’s clear that the Roku app for Tablo needs work, so I just have to hope it will get it as we head towards version 1.0. Fewer changes to things like how series recordings are presented and more attention to having the thing work without a reboot would be appreciated.
I have the same problem with Tablo 4th gen and Legacy, Directtv Streaming, Hulu, and Paramount+, but not any of the other apps I use, so ymmv.
This is rather odd. If you haven’t already @Delegator, would you contact our support team: https://support.tablotv.com/hc/en-us/#contact ?
They should be able to help.
It might also be worth a try to switching how your Roku connects to the internet (Wi-Fi vs Ethernet), if possible.
My Roku is currently wired. Are you saying that I should change it even if wired, just to see whether the change would help?
That’s what he’s saying.
It might be worth a shot. We’re not suggesting you keep it that way, just use this as a trouble-shooting step to see where the issue is located.
